Need Serious Help
Fri Jan 30 2009, 05:01 AM
Hi guys, can I know how much is a serial communication card/adapter cost? Because I am buying one for my project. Thanks!
Also I like to Thank all of you who respond to my thread, also teach me from scratch. Although I cannot see your face, but I would like to sincerely thank you guys. Thank You!
[ Edited Fri Jan 30 2009, 05:02 AM ]
Fri Jan 30 2009, 05:35 AM
Also is it possible to pass value through USB port, as I MAY use serial to usb converter.
Fri Jan 30 2009, 08:22 PM
spiritgate,first congrats that it worked
before we start from scrach, first tell me your main goal. I know that you have a dev board to work on.
Sat Jan 31 2009, 09:48 AM
my main goal is to pass value from RFID to microcontroller then the microcontroller will light up the LED. Now the passing of value can work, but I need another serial port to combine them tgt
Sat Jan 31 2009, 06:04 PM
my main goal is to pass value from RFID to microcontroller then the microcontroller will light up the LED. Now the passing of value can work, but I need another serial port to combine them tgtspiritgate
RFID -> serial port-> micro-controller.
that is the first serial port used. what is the other one for? 'combine "them" together', what is the other part, the PC?
Sun Feb 01 2009, 01:33 AM
I cant connect RFID to microcontroller directly, because RFID need to be run by my VBScript
Sun Feb 01 2009, 05:59 AM
if u are looking for two UARTs (serial ports) in one 8051 core based microcontroller, these are the options:
Atmel
AT89c51RE2
Dallas
DS89c430/DS89c450
else, u can use the software UART as already suggested in previous posts.
Atmel
AT89c51RE2
Dallas
DS89c430/DS89c450
Mon Feb 02 2009, 09:20 AM
ok got my extra com port to work
. I have yet another problem. I need to implement more LED on the development board, where should i put at?
Mon Feb 02 2009, 08:39 PM
why you need a vbscript to make ur rfid work?
do this.. tap your serial port using a free serial port monitor software. see what your VB script is sending to reader and what reader is giving, then you can implement the same on controller. so you can eliminate the use of PC.
It might sound hard to you but its very very easy. and gonna help you a lot
Mon Feb 02 2009, 08:59 PM
You can get a free version of a monitor here
http://www.serial-port-monitor.com/index.html
and it does work.
and it does work.
[ Edited Mon Feb 02 2009, 09:00 PM ]
