Discussion in "New Ideas regarding projects" started by    coolmirza143    Mar 15, 2010.
Fri Mar 19 2010, 11:04 am
you can't say anything unless you have tested it. LDR+ADC can be a great combination.
ya u r rite! I decided to work with LDRs here is an Attachment see this.....wat u think about his work???
Fri Mar 19 2010, 01:07 pm
Hi mirza
very useful PDF. thankyou
Fri Mar 19 2010, 06:45 pm
Welcome Abhinav
Expecting same from ur side
Sat Mar 20 2010, 01:49 am
i also think so that, this can be achived by using LDRs but i am worried about the performance
is it possible to use the sun possition provided by Nasa????
By using this we have to program the controller to rotate the motor after some time intervals! to get the sun possition..... is it possible???
coolmirza143
Man has been tracking the position of the Sun for thousands of years before NASA, but I suppose
they are as good a source as any.
Not only possible but I'd say the best way, but you would need to use a stepper motor.
Sat Mar 20 2010, 04:21 pm
Hi Phil
is it stepper or Servo???
nd me agree wid u abt tracking of sun by Human! Man is much talented as compared to NASA
see this schematic i am hopping to make it working there is a Motor mentioned in schematic type of Motor is not specified!! is it Stepper or Servo or jst simple D.C Motor???
Sun Mar 21 2010, 02:01 am
coolmirza143
Here it is a simple DC motor, it would be a stepper for the "NASA" tracker,
or as I prefer a Greenwich tracker
Thu Mar 25 2010, 01:12 pm
How to use Greenwich Tracker?????
Sun Apr 18 2010, 09:23 pm
@coolmirza
I think moving your pannel according to sun is useless when there will be shadow or clouds in the sky.
You should check at least once about MPPT (Maximum Power Point Tracking). All basic info about MPPT is available on wikipedia.org
Mon Apr 19 2010, 05:15 am
coolmirza143
Basically you get the information from an astronomical source about where in the sky
the Sun will be on that day.
Your micro has a real time clock, so you can work out the Suns position at all times.
Build a geared system driven by a stepper motor to point the panel at where you know the
Sun will be.
Mon Apr 19 2010, 08:06 pm
@ AKC is there any example of MPPT is available??? test circuit or small project???
Richardesord
Mon May 27 2024, 06:16 pm
Stelota
Mon May 27 2024, 06:03 pm
atalethtux
Mon May 27 2024, 03:27 pm
Manuelwob
Mon May 27 2024, 09:06 am
astotiake
Mon May 27 2024, 03:09 am
Anthonyklup
Sun May 26 2024, 07:54 pm
Robertbix
Sat May 25 2024, 11:35 pm
cngCar
Fri May 24 2024, 03:50 pm
